AIP-SSM module hung
Answered Question
Apr 20th, 2010
I have recently confgured my AIP-SSM-40 module in my firewalls which are configured in HA(Active/Standby).It was working fine.Then i upgraded the image version to  IPS, 7.0(2)E3.
It was working fine for a week.Then i found that the secondary firewall was in Secondary failed state.My AIP-SSM in the secondary firewall is not responding.
I could not login the AIP-SSM with session 1 command.Show module command shows
Mod Card Type                                    Model              Serial No.
  0 ASA 5520 Adaptive Security Appliance         ASA5520
  1 ASA 5500 Series Security Services Module-40  ASA-SSM-40
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  0 0021.a09a.d1bb to 0021.a09a.d1bf  2.0          1.0(11)5     8.0(4)
  1 0023.5e15.f6c8 to 0023.5e15.f6c8  1.0          1.0(14)5
Mod SSM Application Name           Status           SSM Application Version
Mod Status             Data Plane Status     Compatibility
  0 Up Sys             Not Applicable
  1 Unresponsive       Not Applicable
at the end of the show failover command shows
slot 1: ASA-SSM-40 hw/sw rev (1.0/) status (Unresponsive/Up)
I suspect SSM module is having the issue.Is there any way to recover.
Correct Answer by Jennifer Halim about 6 years 10 months ago
Try to shutdown and reset the module using this command from the ASA:
hw-module module 1 reset
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Tue, 04/20/2010 - 05:00
uthayaman Tue, 04/20/2010 - 09:30
Thx...
After the reset it is working fine.
Few documents depicts that AIP-SSM module will not play any role with HA of the firewall but why the HA was stuck in my case.
-uthay
Related Content
