CCM6 and MGCP gateway :Called number not seen with "show voice call statu" command
iantra123
Level 3
Level 3
I've configured a CCM with a voice gatway that use E1 PRI.
CCM use SIP and MGCP to make outbound call through the voice gateway.
I will use MGCP at the end. The SIP is just for temporary test.
Question : How to display the called numbe when the E1 port is managed by MGCP?
1/ If I use SIP I can see the called number when I do the show voice call status command
2/ If I use MGCP,then I cannot see the called number when using this same command.
I'm using the voice call status for troubleshooting
DescriptionCallIDCallIDccVdbPortDSP/ChCalled #Codec Dial-peers
SIP call0x979B733C50x483A9C400/2/0:15.230/6:1*033140599g711ulaw0/51
MGCP call0x979D211E20x483AB6800/3/0:15.310/3:6*        g711ulaw0/0
SIP call0x97AEB362B0x483A9C400/2/0:15.210/6:6*0320413446g711ulaw0/51
Is there any solution?
Or I have to see the CDR? But its result is not instantly
Best regards,
Antra
Ayodeji Okanlawon
Have you tried "show isdn active"
Please rate all useful posts
I've tried, but it just show the calls that use SIP calls  :
All calls that display star and nothing after are calls made from MGCP
rtVg00#sh voice call status
CallID     CID  ccVdb      Port        DSP/Ch  Called #   Codec    Dial-peers
0x9880F    FB3  0x483A9C40 0/2/0:15.25 0/5:1  *0320418297 g711ulaw  0/51
0x98ABB    12ED 0x483AB680 0/3/0:15.27 0/3:5  *           g711ulaw  0/0
0x98ADA    13E2 0x483A9C40 0/2/0:15.27 0/6:6  *0320262734 g711ulaw  0/51
0x98AE7    12F8 0x483AB680 0/3/0:15.31 0/3:1  *           g711ulaw  0/0
0x98AEB    12F9 0x483AB680 0/3/0:15.30 0/3:3  *           g711ulaw  0/0
0x98AEF    12FA 0x483AB680 0/3/0:15.25 0/6:2  *           g711ulaw  0/0
0x98AF7    12FC 0x483AB680 0/3/0:15.28 0/6:5  *           g711ulaw  0/0
0x98AFA    1412 0x483A9C40 0/2/0:15.22 0/4:4  *0320263654 g711ulaw  0/51
0x98B02    141E 0x483A9C40 0/2/0:15.26 0/5:3  *0331184452 g711ulaw  0/51
0x98B26    1454 0x483A9C40 0/2/0:15.21 0/4:5  *0327615059 g711ulaw  0/51
0x98B43    130F 0x483AB680 0/3/0:15.24 0/4:1  *           g711ulaw  0/0
0x98B57    1314 0x483AB680 0/3/0:15.22 0/6:4  *           g711ulaw  0/0
0x98B7A    14D2 0x483A9C40 0/2/0:15.31 0/3:2  *0320267304 g711ulaw  0/51
13 active calls found
ORArtVg00#show isdn active
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
Out       90017  0320262734                    90 Unavail   -          0
Out       90218  0331184452                    69 Unavail   -          0
Out       90016  0320263654                    63 Unavail   -          0
Out       90045  0327615059                    35 Unavail   -          0
rtVg00#
Then you need to run a "debug isdn q931" and be sure you can see the Calling and called number from the MGCP gateway.
This appers in the show isdn status
rtVg00#sh isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/2/1:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 5
This is the config in the controllers :
controller E1 0/2/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31 service mgcp
description Test E1 PRI
interface Serial0/2/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
