nelson.garcia Tue, 04/20/2010 - 07:12
I'm going to assume it depends on what kind of switch you're talking about. Different switches have different capabilities.
In the case of a Cisco Catalyst 3560 switch: Up to 1024 VLANs and up to 128 spanning-tree  instances per switch are supported.
sandrello Tue, 04/20/2010 - 07:17
is there a way to find those info per switches model?
nelson.garcia Tue, 04/20/2010 - 07:32
Of course, all I did was a google search for "Catalyst 3560 spanning-tree instances" and the first link was the product Data Sheet for the 3560.
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
You can substitute the 3560 for whatever switch you're wondering about.
You can find Data Sheets for whatever switch you want here:
http://www.cisco.com/en/US/customer/products/hw/switches/index.html
Jon Marshall Tue, 04/20/2010 - 07:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It's usually contained with the data sheet. Start here -
Switches
then select the switch you are interested in, scroll down the page and near the bottom will be a link for the data sheet.
Jon
