RV082 VPN bug
Apr 20th, 2010
I have a problem with a VPN tunnel which works partially.
For  your understanding I will explain the context:
I have two routers in  the network, one used as a gateway (router 'A' – IP 192.168.0.1) and  one for creating the VPN tunnel (router "B" – IP 192.168.0.30), both  have public addresses on the WAN  and both have the LAN interface  connected in the same network.
IP address allocation is done by a SBS  W2K3 server.
All workstations have the router “A” as gateway and  are in the same class
When the VPN tunnel is up I can not reach from  outside the local network workstations (IP 192.168.0.3 - for example), I  can see only internal IP router “B”, although the tunnel is passed all  class configuration addresses (Local Security Group Type : Subnet )
When  I change the configuration of a workstation and put the router "B" as  gateway instead of "A" everything goes OK.
The same symptoms are  when I try to forward a external port to an internal IP.
I think  is a bug in the firmware.
I have the latest  firmware 2.0.0.19-tm
David Hornstein Tue, 04/20/2010 - 08:01
  • Gold, 750 points or more
Little hard to fathom, could you possibly put together a simple network diagram to illustrate the network topology, both local and remote networks.
(doesn't have to be too fancy)
But I'm also guessing from the information above,  that you have a static route defined in router A that points to the remote network with a nexthop being router B, 192.168.0.30 ?
Dave
