Enable essentials license?
Apr 20th, 2010
I have 5505 that I'm using a test bed for SSL VPN on new 5520 hardware.  We're just going to use Essentials license so I'd like the 5505 to have the same features enabled/disabled as our production equipment will have.
How can I get the 5505 to work like it has only an Essentials License? Right now it's using the basic 2 user premium that it's the default.
Jennifer Halim Tue, 04/20/2010 - 14:27
I assume you have purchased the AnyConnect Essential license for the ASA 5505, and configure the activation key for the AnyConnect Essential license?
Also, for AnyConnect Essential license, you need to be running ASA version 8.2.x.
Lastly, to enable AnyConnect Essential:
Hope that helps.
