Design Assistance
Apr 20th, 2010
We are adding 3 mpls sites that will terminate into a 3750 but cannot rurn EIGRP. This 3750 also terminates other Metro LAN offices as well that run EIGRP.  Am I better off running OSPF and redistributing between EIGRP or running static routes for the MPLS?
Thanks in advance.
Jon Marshall Tue, 04/20/2010 - 09:02
Thanks in advance.
Personally for 3 sites i would use statics and simply redistribute those statics into EIGRP. Easier to configure and a less overhead on the switch not having to run another dynamic routing protocol.
Edit - the above assumes you don't have a huge amount of statics per site, hopefully you can summarise each site ?
Jon
jgorman1977 Tue, 04/20/2010 - 09:27
Jon,
Thanks for the advice. Another question for you about the 3750.  The provider gave me a CE ip, so I would just create a layer 3 interface for that ip and create a vlan interface for our Internal subnet?  I get confused on the 3750.
Jon Marshall Tue, 04/20/2010 - 11:29
jgorman1977 wrote:
Jon,
Yes. On the port that connect to the provider -
int gi1/0/1
no switchport
ip address x.x.x.x
and then for your internal vlans you just have L3 vlan interfaces eg.
int vlan 10
ip address 192.168.5.1 255.255.255.0
etc. for each vlan.
Jon
