Help with cwcli
Answered Question
Apr 20th, 2010
Solaris 10, LMS3.2, RME4.3.0
I'm trying to export rme devices into an XML format and tried to use one of the command and it retured with the following error. I have more than 450 managed devices. What I could be doing wrong?
</code></p><p class="pBody"><code class="cExBold" style="font-weight: bold;">cwcli export inventory -u admin -p admin -f myinv.xml
cwcli export inventory -u admin -p admin -device device%
og4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: /var/adm/CSCOpx/log/license.log (Permission denied)
        at java.io.FileOutputStream.openAppend(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
        at java.io.FileWriter.<init>(FileWriter.java:61)
        at org.apache.log4j.FileAppender.setFile(FileAppender.java:284)
        at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:198)
        at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:239)
        at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:247)
        at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:123)
        at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)
        at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:637)
        at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:595)
        at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:522)
        at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:412)
        at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:309)
        at org.apache.log4j.PropertyWatchdog.doOnChange(PropertyConfigurator.java:665)
        at org.apache.log4j.helpers.FileWatchdog.checkAndConfigure(FileWatchdog.java:80)
        at org.apache.log4j.helpers.FileWatchdog.<init>(FileWatchdog.java:49)
        at org.apache.log4j.PropertyWatchdog.<init>(PropertyConfigurator.java:657)
        at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:373)
        at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:355)
        at com.cisco.nm.license.client.LicenseManager.<clinit>(LicenseManager.java:62)
        at com.cisco.nm.rmeng.common.VerifyRMELicense.validate(VerifyRMELicense.java:70)
        at com.cisco.nm.rmeng.cli.framework.CwCli.doStuff(CwCli.java:151)
        at com.cisco.nm.rmeng.cli.framework.CwCli.main(CwCli.java:283)
SUMMARY
        Failed: export: Could not obtain any devices.
Recommended Action:
1.Check whether devices are in RME.
Correct Answer by Joel Monge about 7 years 1 week ago
Try this instead:
./cwcli export inventory -u admin -p admin -device %
Overall Rating: 5 (1 ratings)
Correct Answer
Joel Monge Tue, 04/20/2010 - 11:14
  • Cisco Employee,
Try this instead:
