DTMF Tones Issue SIP to SIP - CUCM 7.x with CUBE
Answered Question
Apr 20th, 2010
Hello All,
           I have what appears to be a DTMF issue.  The setup is a CUBE doing SIP to the provider and SIP to CUCM 7.x (1 sub and 1 pub).  When I call lets say cisco for instance and press 1, everything is fine it accepts the entry.  The issue is with the service Global Connect.  Global Connect can be used to send a voice message to multiple call destinations.  Basically you browse to there site and give them a number and it calls you back.  So we give them the number of a DID on our CUCM system.  It calls the phone and then you record at the tone and press #.  The # is accepted but you need to press "1" to send the message and the "1" is not being accepted.  What debugs can I use to see what is going on when i hit the "1", on the CUBE?  all other DTMF seems fine both in and our but this.  thanks
Jason
Correct Answer by walshliam about 6 years 11 months ago
We had a simililar DTMF issues when we configured CUBE adn SIP. After much troubleshooting, a Code upgrade on the router was the fix. Are you working with TAC?
Overall Rating: 5 (1 ratings)
Correct Answer
walshliam Tue, 04/27/2010 - 06:08
