Nss4000 upgrade failed, shares are not available on encrypted volume
Answered Question
Apr 20th, 2010
After upgrading from 1.12 to 1.16 the shares on the encrypted volume are not shown in the shares list after unlocking the volume.
Restoring a system config from before the upgrade does not change anything
who can help?
jerry
Correct Answer by appsphere about 7 years 1 month ago
Hi Jerry
I  have had the same problem after a successful upgrade.
I found a strange solution to fix this issue, I realy don't know if this works for you.
our setup:
- encrypted volume with 2 shares
- CIFS Access only
Try to do something like this:
- Enable FTP (and the Root directory your encrypted volume)
- After the configuration rebuild I saw my "old" shares, but I couldn't connect
- Add FTP to this shares
- Access via FTP to this volume/shares, that should work
- Disable CIFS Access on the shares
- Remove User rights from the shares
- update configuration
- Enable CIFS access on the shares
- Add rights on the Shares
After this, it works for me.
Don't ask why the shares are there after enablin the ftp, it's seems that after a configuration change on the shares/volume and rebuild the configuration, they get back....
good luck
roger
Overall Rating: 5 (1 ratings)
Correct Answer
appsphere Thu, 04/22/2010 - 00:57
Hi Jerry
our setup:
- CIFS Access only
good luck
roger
jegberts. Thu, 04/22/2010 - 05:04
tnx Roger
this did work BUT after a reboot in shares were gone again
after trying the same setup steps a couple of times I had the same result so I tried something else
- Add FTP to the shares, Disable CIFS Access on the shares
- reboot
after the reboot I could not see the shares anymore even after trying the steps that worked before,
also after creating a new FTP share without the users or groups after a reboot I cannot see the new share. there is something really wrong in rel 1.16
any ideas?
jegberts. Sat, 04/24/2010 - 13:08
had contact with cisco
advice is to
- us explorer (not internet explorer) to go to "//IP-number-of-nss/storage"
(note : make sure you are not connected to nss with explorer)
- login with admin
- goto RAIDA, volume
- Copy all data
- switch to explorer and login on IP address
- delete volume
- Create new shares
- Copy data back
