route restriction
Apr 20th, 2010
Telecom provides branch office connectivity to headQuarter using MPLS.
Single Router at branch office terminates MPLS link, its also the default-Gateway for users.
Routing protocol on LAN is ospf ; Bgp config is provided by telecom
I receive tons of telecom routes which are not needed, how do I restrict telecom bgp routes at the router and allow HQ networks only.
Is it advisible to restrict routes and then apply QOS between HQ and branch office.  Our aim is to provide guarantee bandwidth for Voice application.
thanks
Mathews
Jon Marshall Tue, 04/20/2010 - 15:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mathews.cisco wrote:
thanks
Mathews
Mathews
You should only be receiving routes for your own sites and not lots of other routes. What are these routes ? Do you have just one internet connection at the HQ site and branch sites access internet via HQ ? If so you may also be getting a default-route from your provider.
You should not be getting tons of other routes so it may be worth having a talk with your provider.
As for QOS, if it is across an MPLS  network then you need to talk to your provider about this as well. You can prioritise the voice traffic within your sites but you will also need to talk to the provider about prioritising the traffic within their MPLS cloud which obviously has a cost associated with it.
Jon
