DMVPN hub router sizing recommendations
Apr 20th, 2010
Hi All,
     So I was curious if someone has a rule of thumb for DMVPN hub router sizing.  Something on the order of if you have x remote sites you need at least an 1800/1900 for your hub router, or at y number of sites you need to step up to a 2800/2900, etc etc. I don't have a feel for how CPU intensive being the DMVPN hub is.
Thanks in advance.
RICHARD MESSINGER Fri, 07/20/2012 - 06:41
Looking for a more recent performance doc (this one is 2 yrs old) for a hub and spoke DMVPN configuration with a 2900 series at the core instead of a 2800 or 7200 series.
Would I be safe is taking the numbers for a 28xx and multipluing it by 2 for the same 29xx numbered router?
Alessio Andreoli Fri, 07/20/2012 - 07:11
  • Silver, 250 points or more
Would I be safe is taking the numbers for a 28xx and multipluing it by 2 for the same 29xx numbered router? NO
The Giuseppe's list is one of the most updated. there is one document more you can google "router performance cisco" but that doc is 3 Nov 2009. and it is the last version of that doc because th group doing that job was dimissed.
Don't do assumptions as the ones you meant to do with 28xx and 29xx because with the new licensing systems ther are new parameters you need to take into account.
Alessio
