AP541N with WDS and Clustering
I have two AP541's, one which can be cabled to the LAN.  The second one will not be on a LAN and I've enabled WDS and Clustering.  Will I be able to take advantage of the Clustering capabilities in this topology?  Will I be able to mange the second box using its LAN IP address even though access to it will be across the WDS bridge?
Glenn Quesenberry Thu, 05/06/2010 - 12:09
Yes, you should have no trouble clustering that AP and reaching it over the Wireless LAN.  You will need to connect it via a cable initially to set it up however.
Best Regards,
Related Content
