Check whether User initiated its VoiceMail Box
Answered Question
Apr 21st, 2010
Hello Guys,
unfortunately I could not find a database dictionary like for callmanager to find a way by myself. Maybe you can provide me one?
I need to know whether there is a way to check if a user ever used its voice mail box from unity connection.
Thanks for help!
Correct Answer by Rob Huffman about 7 years 2 months ago
Hi there,
Can you try setting this as a "first" step;
To Change the Database Proxy Service Shutdown Timer
Step 1 In Cisco Unity Connection Administration, click System Settings > Advanced > Connection Administration.
Step 2 In the Database Proxy: Service Shutdown Timer  field, enter a value between 1 and 999 days.
A value of zero disables the Database Proxy Service.
Step 3 Click Save.
Cheers!
Huff
Overall Rating: 5 (5 ratings)
Rob Huffman Wed, 04/21/2010 - 05:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
There is a perfect tool for this type of report. We have used this to search for the same "setup" info.
Check the  "Set for First Time Enrollment" and "Voice name Recorded";
Connection  User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a  Windows-based remote database administration tool available on the Cisco  Unity Tools website. CUDD allows you to export specific information  about users to a file that can be viewed or imported into another  application, such as a database utility or Microsoft Excel. When the  data is exported, the tool automatically creates a header row that lists  the data type found in each column of the output, for ease of import  into other programs.
The tool is available from the "Superb" Unity  Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
From the  Help Notes;
Requirements/Special  Notes
This  version of User Data Dump runs on Windows XP/2000/2003 or Vista.
***This  version of User Data Dump only works with Unity Connection 7.0(1) or  later.
Hope this  helps!
Rob
lindborg Wed, 04/21/2010 - 08:02
  • Cisco Employee,
also, as a side note about the data dictionary - you can get the Data Link Explorer (CUDLI) for Connection here:
http://www.ciscounitytools.com/Applications/CxN/CUDLI/CUDLI.html
this includes full data dictionaries for all versions of Connection that have been released (and a few that haven't) - when you connect with it you can explore tables and columns and stored procedures etc... and the information about thosde tables/views/columns is displayed in the tool (type, what they're used for, what they link to etc...).
tschmolcz Thu, 04/22/2010 - 00:21
Hey Rob,
I face an issue with the needed service "Connection Database Proxy"  . I can't find it under the "Tools" and the related menu points. Unity is running with Version 7.1.2 . I already tried to start the service name by using console, but it didn't work. :-(
@lindborg Thanks!
Rob Huffman Thu, 04/22/2010 - 05:39
  • Hall of Fame,
    Founding Member
Hi There,
Just to clarify this info is related to Unity Connection not Unity as you have
referred to both products in this thread
The path is as follows;
Unity Connection Serviceability > Tools > Service Management > Select Server > Optional Services >
Connection Database Proxy > Activate/Start
You also need to set the Database Proxy: Service Shutdown Timer (in Days)
Unity Connection Administration > Advanced > Connection Administration > Database Proxy: Service Shutdown Timer (in Days)
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
tschmolcz Mon, 04/26/2010 - 06:29
Hello Rob,
ok to clarify my request, I use the Unity Connection.
Nevertheless, there is no Optional Services > Connection Database Proxy > Activate/Start  (take a look at the attachment please) . In order to get sure I already checked the Network and Feature Services, but it is not listed. :-(
The point Database Proxy: Service Shutdown Timer (in Days) was easy to find.
Rob Huffman Mon, 04/26/2010 - 06:42
  • Hall of Fame,
    Founding Member
Hi there,
No worries my friend
You need to look for;
Cisco Unity Connection Serviceability
instead of Cisco Unified Serviceability
Cheers!
Huff
tschmolcz Mon, 04/26/2010 - 06:48
Oh Now I feel a bit sheepish ;-) . I shouldn't work on too many things at the same time. Thank you again.
### update
activate service failed: Connection Database Proxy
Ok time for looking through the unity logs :-)
Correct Answer
Rob Huffman Mon, 04/26/2010 - 07:06
  • Hall of Fame,
    Founding Member
Hi there,
Step 3 Click Save.
Cheers!
Huff
tschmolcz Thu, 04/29/2010 - 00:29
Hello Rob,
yes changing the time value was the first step I did. Any further ideas? I'd like to solve it.
Just als note for other users - for checking if a voice box is used at all, even if the setup is completed
you can use the method -> Below "tools->reports" there exists  a report function -> Unused Voice Mail Accounts Report .
tschmolcz Thu, 04/29/2010 - 01:20
A small update, unity monitoring tool cannot provide any log file for the database proxy unfortunately. The Application and System log does not show any unusual entries.
