Serial extender with AUX or hwic-t1
Apr 21st, 2010
I have two offices connected to each other with cisco routers at each location. I have a weather sensor at one site and they want the display at the other. The sensor normally connects to the display via a basic rs-232 asynchronous dce/dte 8N1 9600 baud connection. Can I use the AUX ports or maybe hwic-t1s at each router and bridge the ports together to extend the rs-232 connection over the network?
Paolo Bevilacqua Fri, 04/23/2010 - 10:10
You use the AUX port for this. There is also virtual COM software for the PC so not needing the physicial setup on other site.
lostngone Sat, 04/24/2010 - 12:33
Thank you for your response.
Things like reverse telnet and COM port redirector software won't work because the remote display we are using is a piece of standalone hardware not a PC.
