Procurve 5304xl and Cisco 3560
Apr 21st, 2010
I am trying to make operational inter-vlan routing between Procurve 5304xl as core switch and Catalyst 3560 as access switch, I have tried multiple time to make operation inter-vlan routing but no home. Actully I have 3560 PoE switch and I need to start IP telephony.
Any help for solution ? thank you in advance for solution.
Jon Marshall Wed, 04/21/2010 - 01:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Zeeshan
Have you tried looking on the HP site for their config docs ?
What exactly is the problem ? If the procurve is actually doing the inter-vlan routing then on the 3560 switch all you need is the vlans created at L2 and a trunk link back to the procurve switch.
Jon
Zeeshan Aziz Wed, 04/21/2010 - 02:27
Hi John
I had go through at HP site but I just found number of same queries and no one able to solve the mystry to get solution. In fact what you asked I had tried the same by making 3560 as L2 but didn't work. I was able to manage and start communication between HP and 3560 switch, but when I tried to configure two access vlan ports on each, as I had PoE 3560 to start IP telephony, but communication did not work with two vlan (one for voice and one for data) on each port of Catalyst 3560.
