PuTTY - Strange packet received: type 3
Apr 21st, 2010
Hi!
I have a strange problem when I use putty 0.60 to connect to the router via ssh: putty occasionally opens a window with error the following message: "Strange Packet Received: type 3" and terminatig comunication with router.
The problem occurs on some recent versions of IOS, in particular the 12.4 (24) and various hardware platforms.
Any idea to solve this annoying problem??
73
Arturo
Overall Rating: 2.7 (5 ratings)
Thomas Schmidt Tue, 04/27/2010 - 04:15
Hello Arturo,
unfortunately I have no solution, but at least I can confirm it.
We are also using Putty 0.60 and are facing the problem only with new C29xx routers with IOS 15.0
Any help is higly appreciated as this behaviour is really annoying.
Best Regards
Thomas
paolo bevilacqua Tue, 04/27/2010 - 06:20
  • Hall of Fame,
    Founding Member
Most IOS versions have this problem.
The only workaround is to use telenet instead.
Kevin Brennan Tue, 04/27/2010 - 07:28
  • Bronze, 100 points or more
Hi All,
Just a thought if it affects your sessions to some router all of the time.
If your IOS feature set allows it, you could encrypt telnet traffic between your routers and management workstation(s). And then disable SSH untill the problem is fixed.
It's a bit messy and has a high administrative overhead, but it would secure management traffic.
Kevin
hugo.ouellet Thu, 04/29/2010 - 12:55
In putty config go in Connection->SSH->Kex
Change
Max minutes before rekey to 0
Max data before rekey to 0
The strange packet type 3 error happen on rekey...
You can set it to 1min to see it happen faster.
It solved the problem for me.
Thomas Schmidt Fri, 04/30/2010 - 01:09
Hi Hugo, hi all,
this was really the hint I was looking for. Great!
With a first quick test the problem wasn't seen anymore.
I'll do a few more tests within the next days and report back.
Best regards
Thomas
Thomas Schmidt Tue, 08/03/2010 - 02:26
Hi all,
I would just like to confirm that the problem wasn't seen after chaning the mentinoend parameters in putty.
As far as I understand this leads to stop of key exchange in each SSH session. I'm not sure how much security would be degraded by this.
I guess for us it is acceptable as we are using this only for our internal enterprise network.
Anyway, on long term we would appreciated to get it fixed permanently by Cisco or putty developers.
Best regards
Thomas
Arturo Bianchi Fri, 04/30/2010 - 01:35
Hi Hugo,
good info... I have turned the information to the mailing list of putty developers where I was reporting a series of log for catch the bug (Simon Tatham had introduced some new flags in the current version to better identify the problem) !!!
good interim workaround .
73
Arturo
wsanders1 Mon, 08/02/2010 - 17:56
Hate to bump an old thread, but this is the top Google search for this error. FWIW we did not start seeing this until we upgraded from c3845-ipbasek9-mz.124-22.T.bin to c3845-entservicesk9-mz.124-24.T3.bin.
Setting the PuTTY rekey interval to 0 (disabling rekey) will help and is still most likely more secure than using telnet..
gherbstman Fri, 12/24/2010 - 04:12
We have also been seing this problem for a long time with most versions of IOS. Very annoying. Nice to find a work around but it would be even nicer to see this fixed.
Hey Cisco, can you please address this!
Arturo Bianchi Fri, 12/24/2010 - 06:51
Hi!
In fact I could not say how much of the problem is attributable to IOS, and than it is to Putty; ultimately, when I use ssh on Linux the problem does not occur. There are two things: or openssh already has an automatic workaround or is there something more! At the time, I read the opinion of Simon Tatham: in fact I still lack the position of some Cisco employees on this annoying defect.
Happy holidays
73,
Arturo
tahequivoice Tue, 12/03/2013 - 11:29
I just started having this problem, but only with ASA, and only when doing a ping with no reply. I get this error on the 2nd or 3rd ?.
Very strange, and setting kex to 0 did not help.
Related Content
