CUPC V2 is working with CUPS V7, while CUPC V7 is not
Apr 21st, 2010
Dear all,
We did upgrade for all of our VOIP Enviroment as follows:
Call Manager from 5 -> 7
Unity from 5->7
Presense 6->7
and everything is working fine, except the newer version of  Cisco unified personal communicator 7 is not able to connect to the presene server!!!
I attached a screenshot for both version of the CUPC. and i attached the problem report generated by the CUPC.
Kindly help me
Thanks & Best Regards,
htluo Wed, 04/21/2010 - 04:57
  • Red, 2250 points or more
If you look at the screenshot of the non-working one, the FQDN was CUPS.CUPS.awqaf.gov.kw.  I don't think that's right.
To support failover feature, CUPC V7 use "node_name+proxy_domain" as "prsence address".  (if "node_name" contains "proxy_domain", it'll use "hostname").
You may find/edit "node_name" from CUPS > System > Cluster Topology.
You may find/edit "proxy_domain" from CUPS > System > Service Parameters > Cisco UP SIP Proxy.
Thanks!
Michael
http://htluo.blogspot.com
eemara949 Wed, 04/21/2010 - 23:32
Dear htluo ,
Thanks a lot for your help; I did what you said to change the proxy domain, but unfortunately still not working. I attached the screenshot
htluo Thu, 04/22/2010 - 04:57
Are you able to ping "CUPS.awqaf.gov.kw" from the CUPC computer?
Thanks!
Michael
eemara949 Sat, 04/24/2010 - 23:31
Yes I am able to ping:
H:\>ping cups.awqaf.gov.kw
Pinging cups.awqaf.gov.kw [10.21.0.102] with 32 bytes of data:
Reply from 10.21.0.102: bytes=32 time<1ms TTL=63
Kindly update,,,
htluo Sun, 04/25/2010 - 05:49
Try the following command to see if the client can connect to SIP Proxy:
telnet cups.awqaf.gov.kw 5060
If yes, then go to CUPS > System > Security > Incoming ACL.  Add an ACL with description "All" and address pattern "All" (without quotes).
Michael
eemara949 Mon, 04/26/2010 - 03:12
Dear htluo ,
I did as you mentioned, i got better result than before!! ,CUPC keeps connecting and disconnecting with the CUPS!!!!!
At least we saw conncected status
htluo Mon, 04/26/2010 - 04:56
Then we need a packet capture and problem report from CUPC.  Make sure "enabled detailed logging" was turned on from CUPC > Help.
Michael
