Is there any free software to monitor voip traffic / calls
Apr 21st, 2010
Hi all
Im having a few issues with some voip call's bad quality etc, is there any free tools out there where I can get some diagnosis?
cheers
Carl
harisivaji Wed, 04/21/2010 - 07:52
Its mostly related to Codec G711 will use 83Kbps you can also change it to other codec G729 or G723 which uses 24kbps only
if you want to check call quality and Codec you can use Wireshark
if u r using cisco IP communicator which has inbuilt diagnostictools
Hari
