Genereted password for Guest account the WLC2106 is not printable
Apr 21st, 2010
when i'm using lobby account to create a new guest web account, there is possibilty to generate a password for that account
Unfortunately this password apperas only in the window when you create it
There is no other record about it
So the only way is to write down this password
Do you have any idea how can i store it and print it ?
sschmidt Wed, 04/21/2010 - 10:24
From the guest user list you can use the pulldown and choose Print/Email User Details and see the password.
Does this work for you?
peter_jevos Thu, 04/22/2010 - 01:01
Thank you for your answer
unfortunately I cannot find any pull down menu?
All i can do is to do the print screen and then paste it to some Word
Where this pulldown should be located ?
sschmidt Tue, 04/27/2010 - 10:07
Ahh ok.  I do not remember seeing a way to see the password in clear text on the controller UI.
Patrick Meyer Thu, 06/23/2011 - 05:57
is there a way to view the guest user's password from the controller's CLI?
