'ACS invalid password' when add user thru FTP RDBMS sync
Apr 21st, 2010
i add user using FTP RDBMS sync using .csv files
the data inside the .csv looks like this
1,1,2009409802,student,100,"",890425036066,"","",04/21/2010,"","","",0
from the log, the sync is success, check the user also available inside the ACS after the sync,
but the problem is the password is invalid.
however if add user manually at ACS, (set user & pass) no problem.
what could be the problem?
