BSCI Lab setup
Apr 21st, 2010
Guys
I am currently setting up my BSCI lab and wanted a few pointers, if possible? I can gather most hardware from my work so if anyone has any suggestions re equipment to add then please throw it out there and I will let you know if its possible to grab it from work!
So far I have
1 x 2610
1 x 2611Xm-RPS
1 x 2612
1 x 2620
2 x 2800 (not sure of model as at another site)
I dont know the current IOS versions but I will upgrade prior to setting the lab up. I also have 1 x WIC1T and 1 x WIC2T - I am guessing I will need to invest in some more WIC cards??? I currently have 4 x X.21 DTE/DCE cables
Also I have a couple of 3560 L3 switches I can utilise if required - how does this sound???
Any help at all greatly appreciated
Collin Clark Wed, 04/21/2010 - 06:27
IMO that is plenty of equipment. You should be able to do everything with that you have. I would not worry about more serial WICs either. Good luck in your studies.
