Alert when ASA Failover happens?
Answered Question
Apr 21st, 2010
Are there any tools that will alert/Email, snmp Trap...... when the ASA's ( in failover configuration) failover from primary to secondary?  and Vice a Versa.
thanks
Correct Answer by Gerard Gacusan about 7 years 2 months ago
Try this and it works for me when failover mates change and sends alert immediately... This sends both syslogs messages 7 and mail. For traps syslog, o enable debug fover commands on both devices if you need to troubleshoot further of the failover changes in details (pcap).. Hope this helps...
logging enable
logging timestamp
logging standby
logging buffer-size 10000
logging buffered warnings
logging trap debugging
logging mail critical
logging from-address [email protected]
logging recipient-address [email protected] level errors
logging facility 23
logging device-id hostname
logging host inside x.x.x.x
Correct Answer by Jennifer Halim about 7 years 2 months ago
Yes, syslog message# 104001, 104002
There are a few more within the 104xxx range in regards to failover that you might be interested:
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4768649
Hope that helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Gerard Gacusan Wed, 04/21/2010 - 06:52
logging enable
logging timestamp
logging standby
logging facility 23
logan-7 Wed, 04/21/2010 - 07:12
thanks that is exactally what I was looking for.
