Cannot boot WLC 2106
Apr 21st, 2010
I have been trying to upgrade my WLC 2106, but it is stuck at rommon/grub mode.The steps are as follows
rommon #5> tftpdnld
ROMMON Variable Settings:
  ADDRESS=192.168.100.1
  SERVER=192.168.100.10
  GATEWAY=192.168.100.10
  PORT=Ethernet0/0
  VLAN=untagged
  IMAGE=AIR-WLC2100-K9-6-0-196-0.aes
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
tftp [email protected] via 192.168.100.10
Received 64636284 bytes
Bad magic number (0x8be58955)
rommon #6> reboot
Rebooting....
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)6 08/21/06 17:26:53.43
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)7) #2: Fri Oct 13 10:52:36 MDT 2006
Cisco Bootloader (Version 4.0.191.0)
                      .o88b. d888888b .d8888.  .o88b.  .d88b.
                     d8P  Y8   `88'   88'  YP d8P  Y8 .8P  Y8.
                     8P         88    `8bo.   8P      88    88
                     8b         88      `Y8b. 8b      88    88
                     Y8b  d8   .88.   db   8D Y8b  d8 `8b  d8'
                      `Y88P' Y888888P `8888Y'  `Y88P'  `Y88P'
Booting Primary Image...
Press <ESC> now for additional boot options...
Detecting hardware . . . .
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 4.0.217.0
Initializing OS Services:
ok
Initializing Serial Services: ok
Initializing Network Services: ok
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting Fast Path Hardware Acceleration: ok
Starting Switching Services: ok
Starting QoS Services: ok
Starting FIPS Features: Not enabled
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Management Frame Protection: ok
Starting LWAPP: ok
Starting Crypto Accelerator: Not Present
Starting Certificate Database: ok
Starting VPN Services:
ok
Starting Security Services: ok
Starting Authentication Engine: ok
Starting Mobility Management: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Power Over Ethernet Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
starting TSM: ok
Starting CIDS Services: ok
Starting Ethernet-over-IP: ok
Starting Management Services:
   Web Server: ok
   CLI: ok
   Secure Web: Web Authentication Certificate not found (error).
(Cisco Controller)
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
System Name [Cisco_37:d1:c0]:
Enter Administrative User Name (24 characters max): cisco
Enter Administrative Password (24 characters max): *****
Management Interface IP Address: 192.168.10.1
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 192.168.10.10
Management Interface VLAN Identifier (0 = untagged): 0
Management Interface Port Num [1 to 8]: 1
Management Interface DHCP Server IP Address: 192.168.10.10
AP Manager Interface IP Address: 192.168.10.25
AP-Manager is on Management subnet, using same values
AP Manager Interface DHCP Server (192.168.10.10):
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: no
Network Name (SSID): cisco
Allow Static IP Addresses [YES][no]: no
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code (enter 'help' for a list of countries) [US]: US
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
Configuration saved!
Resetting system with new configuration...
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Invalid Key: 000D
Invalid Key: 000D
Invalid Key: 000D
Platform AIR-WLC2106-K9
Ethernet0/0
MAC Address: 001b.2a37.d1c8
Link is DOWN
Use ? for help.
rommon #0>
But the result is same. Can anyone please help me.Any link to the document will be appreciable.
Manu
dancampb Wed, 04/21/2010 - 06:45
Check out bug CSCsd52483.  You probably want to try to boot from the secondary image to get the controller up.  Then follow the upgrade steps outlined in the release notes to get to the version of code you want to upgrade to.
Nair Manu Thu, 04/22/2010 - 01:13
Hi dancampb,
  Thanks for the immidiate update. I went through bug  CSCsd52483 using the document http://www.cisco.com/en/US/docs/wireless/controller/5.0/configuration/guide/c5mfw.html#wp1053397 . I tried to upgrade  Bootloader Version  4.0.191.0 to AIR-WLC2100-K9-5-0-148-0-ER.aes using both CLI and GUI unfortunately the bootloader is not getting updated and afer reboot it is going back to rommon mode again. From there I need to manually boot the controller.
Any suggessions from your end will be appreciable.
Manu
dancampb Thu, 04/22/2010 - 06:29
You may just want to open a TAC case and have the controller RMA'd.
UST GLOBAL Wed, 10/16/2013 - 00:12
Thanks for the suggestion, solved the booting issue by re-seating the flash in the WLC
SPK
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
