1130 AG AP and Broadcast of the SSID
Apr 21st, 2010
We have 3 1130's installed and 2 vlans, one public and one private. I need to broadcast my private SSID but cannot find the setting to allow this. Can someone advise me on the location of the setting?
chaz
Kayle Miller Wed, 04/21/2010 - 06:43
  • Silver, 250 points or more
Charles,
     I assume you are using IOS (Autonomous) Access points.. if so you need to enable guest-mode on the Dot11 SSID
so it would look something like this
dot11 ssid private
    vlan x
    guest-mode
Hope this helps.. Please feel free to rate it.
chaznsc@@ Wed, 04/21/2010 - 07:28
Forgive my response/confusion but in using the web interface, where is this setting held?
bcolvin Wed, 04/21/2010 - 18:53
  • Bronze, 100 points or more
It should be under Security -> SSID towards the bottom of the page you will need to scroll the select Guest ID and the SSID you want broadcast.
Bill
chaznsc@@ Wed, 04/21/2010 - 18:55
Dumb follow up, but the device cant broadcast both SSID's?
Leo Laohoo Wed, 04/21/2010 - 19:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes, you can broadcast up to 16 SSID.
chaznsc@@ Wed, 04/21/2010 - 19:34
I can get one or the other to broadcast but not both. What am I doing incorrect?
Leo Laohoo Wed, 04/21/2010 - 19:37
  • Hall of Fame,
    2017 LAN, Wireless
Go to Security > SSID Manager.  Highlight the SSID you want and go down and tick "Set SSID as Guest Mode".
Leo Laohoo Wed, 04/21/2010 - 20:36
  • Hall of Fame,
    2017 LAN, Wireless
Don't forget to rate our posts.  Thanks.
Trending Topics - Security & Network
