Unity cannot record messages
Apr 21st, 2010
I installed Unity 7.0 at a costumer. It works great.
Now we have the problem that a caller cannot record a message. It is possible to listen to old messages but not to record new messages.
In the eventlog there is an error 1394 CiscoUnity_ConvSub but the system cannot view the description.
The conncted exchange is version 2007.
Do anyone have an idea?
thanks Achim
David Hailey Wed, 04/21/2010 - 08:29
  • Purple, 4500 points or more
Is this a single user or ALL users?
Jaime Valencia Wed, 04/21/2010 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    2011
Also, does this happen only to external calls? internal calls? both?
You might want to start by running dbwalker and looking for errors.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
astrohmeier Wed, 04/21/2010 - 22:11
it happens to both internal and external calls and it happens for every user not only for one.
I will test the dbwalkerand tell you the result.
thanks Achim
astrohmeier Thu, 04/22/2010 - 02:52
the dbwalker have one error.
It tells me: Internal dbWalker error 94 (Invalid use of Null) in procedure checkDallHandlers of Form frmMain
thanks Achim
nickmac74 Thu, 04/22/2010 - 04:16
Mite want to check the hardware aswell e.g. you not run out of space!
David Hailey Thu, 04/22/2010 - 05:30
Personally, the first thing I would do is re-run the Permissions Wizard but you can re-run it in report mode first to verify that nothing has changed that would hosed up any permissions in your environment.
What is the exact error you receive when you try to leave a message?
Hailey
Please rate helpful posts!
