Two way audio problem in IP Communicator over Cisco VPN
Apr 21st, 2010
Two way audio problem over IP Communicator. couldn’t hear any one when we are in IP Communicator over Cisco VPN. But able to hear if we call any Hard Phone.
nixon1234 Wed, 04/21/2010 - 07:07
We had this problem as well. I set up laptops for our help desk to use the communicator from home using check point secure remote vpn. You would only get 1 way audio this way. We now use Juniper VPN and do not go through a router and it works fine.
harisivaji Wed, 04/21/2010 - 07:19
I read in somewhere else if you are using VPN client then it should be version 5.0 or later
Hari
suresh ssivaselvan Wed, 04/21/2010 - 07:36
Thanks for the reply. Yes we are using CUCM 5.1.3 and it was working until last week.
harisivaji Wed, 04/21/2010 - 08:09
I mean to say VPN client version  should be 5 or later
Try to fix if there is any change in Network seems like RTP routing issue
If your both IP communicator phones are in Remote network and your HQ CCM is behind a firewall with NAT settings, this problem will be arising frequently
Becuase for Remote IPC to HQ IP Phone it just normal RTP communication
Check your RTP is allowed to Remote VPN setting in your VPN server/Router/FW
