GILLA Wallboard problems when upgrading to 7.1 (SR05_Build504)
Apr 21st, 2010
We ran een extensive upgrade from version 5 to 7.1 (SR05_Build504). On version 7 the wallboard was fully operational but after installing the patches and SR the wallboard died. I have checked all option, but all seems ok. Any guidance or suggestions, please shoot,
I checked the database with the sql analyzer running the sql commands out of the Gilla wallboard and this returns the correct data.
thanks
Ger
amiguel123 Tue, 04/27/2010 - 16:02
We are using Wallboard ver1 on UCCX 5.0 Not sure if there is another verson for wallboard.
I dont know the answer to your issue but i will be following this thread.
Andy
Nathan Luk Wed, 04/28/2010 - 20:55
  • Bronze, 100 points or more
I've done 2 upgrades from 5 -> 7 who use the Gilla wallboards with no real issues. Check SQL server/MSDE perhaps? Verify the wallboarduser login configured in the wallboard ini file still has permissions to read from the database.
Cheers,
Nathan
Related Content
