Unable to print using L2L Tunnel
jnarenkivicius
Hi All,
I have a situation where site A accesses a program at site B though a L2L tunnel
The tunnel is up and functioning and the users can access and use the program with no issues but when they try to print from the program to a printer at site A it does not print.  The admin at site B can see the print jobs in the queue at his site. He can also ping the printer from site B
site A 192.168.0.X
site B 192.168.10.X
printer at site A is 192.168.0.21
Note: the issue coincides with the addition on another L2L Tunnel that I created and had to NAT it to a different IP for that tunnel
I did back out this changes and the issue with the printing still happened so I am not sure if it was the cause
Jason
Jennifer Halim
Try lowering the MSS value on your LAN interface --> ip tcp adjust-mss 1260
OR, if it's an ASA firewall --> sysopt connection tcpmss 1260
Hope that helps.
I adjusted the setting per your suggestion:
But still no joy.  Do we need to reestablish the tunnel or should the change be immediate?
Jason
You would need to re-establish the TCP connection from your PC towards the printer.
