21 mask network on wireless
Apr 21st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I currently have 4 controllers with multiple vlans configure for one ssid.  The vlans are group by building and each vlan is a /24 network.   I have been asked to create one vlan per controller with a /21 network.  I am worried about the size of this network and impact it will have on my wireless users.   Do I have an issue with possible packet collision in wireless?  Also I currently don’t allow wireless users, via the check box on the controller, to talk to each other will this stop the broadcast issues with such a large network?
Overall Rating: 5 (2 ratings)
BRYN JONES Fri, 04/23/2010 - 07:04
Hi Steve
I do know that there is a University in the USA using /21 on their wireless:
950 APs
Peaks of 1000-1300 concurrent users
/21 network is assigned
About 50-60 packets per second of Broadcast
jilahbg Fri, 04/23/2010 - 07:48
We are talking about different kind of broadcasts/collission:
RF: Each AP talks at a certain channel to all associated clients. Only one can talk at the same time. Thats why it´s not a good idea to have too many clients per AP.
IP: An IP-network is a IP broadcast-domain. That means that clients that sends broadcasts (l2 or l3) talks to all other devices within the same broadcast-domain. However, when talking about Cisco WLC-solution the IP-network size is irrellevant as long as the wlc is configured the right way. You can configure the system to not allow client to client-traffic as well as not allowing broadcasts. That´s why you can have thousands of clients in the same IP-network when using Ciscos leightweight wireless solution.
Br Jimmy
stevechapman_2 Fri, 04/23/2010 - 08:46
I currently have the peer to peer blocking set to drop so this stops client to client right?  Does this block the broadcast or is there something else I need to configure like broadcast forwarding?
Note:  I am running version layer 3 mode.
thanks for your help
Steve Chapman
LAN Engineer
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
