Does DID card support in MGCP?
Answered Question
Hi Guys,
Since I am newbie in VoIP. May I know can a DID card support in MGCP? I only know this card can support in H.323.
If yes, could you please specified the command or show me the reference link?
Thanks in advance
Correct Answer by Walter Solano about 7 years 4 days ago
You can do a mix and have the FXS/DID ports working as H.323 endpoints and the rest been manage by the MGCP protocol, or you could use everything in H.323.
Walter Solano
CCNA Voice
Cisco UCCX Specialist
Overall Rating: 5 (2 ratings)
Walter Solano Mon, 04/26/2010 - 05:24
  • Gold, 750 points or more
Hello Kam,
As you mention the FXS/DID feature is support for H.323 gateways without any issue; but at this point we are not able to use or configure this feature for The MGCP Gateways.
Walter Solano
CCNA Voice
Correct Answer
Walter Solano Tue, 04/27/2010 - 09:41
Walter Solano
CCNA Voice
