Catalyst 6513 with FWSM - Adding new VLAN - Confused!!
Apr 21st, 2010
Hi all,
I inherited a fairly large network.  Dual 6513's with single fwsm's.  When I log into the switch we have 8 vlans configured.  I am really confused on how to get started.  What I think needs to be done is first the vlan is created on the switch.  Then using the firewall vlan group command I would add this new vlan.  Then it will magically show up in the fwsm?
Reading the following article:  http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00808b4d9f.shtml
It only add's one vlan to the msfc, vlan 20.  And then it configures the rest of the vlans on the fwsm?  This is backwards of the way mine looks to be configured.  Also, all of my vlan's on the msfc are shutdown.  That part is weird to.
From what I read, you can configure it this way but it lists a secuirty disclaimer when doing this.
For security reasons, by default, only one SVI can exist between the MSFC and the FWSM. For example, if you misconfigure the system with multiple SVIs, you can accidentally allow traffic to pass around the FWSM if you assign both the inside and outside VLANs to the MSFC.
This post is probably more confusing that it's worth.  But if someone could give me some insight into adding a vlan into this env that would be great.
Jon Marshall Wed, 04/21/2010 - 09:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have a read of this thread and then come back if you need further clarification -
FWSM basic configuration
Jon
packetzen Wed, 04/21/2010 - 09:13
Yes, I had read this before and it is very helpful but it also raised a lot of questions for me.  I guess I'm
still trying to understand how my vlans are configured. Particularly since they are shutdown on the catalyst switch.
It looks to me like I am using multiple svi's on the switch that pushes to the fwsm.
firewall multiple-vlan-interfaces
firewall module 10 vlan-group 1
firewall vlan-group 1  2-4,6,7,9-11,13,14,17-20,500-502
I then have these vlane interfaces on the switch, with static routes etc.  Here is an example of one of the vlans listed above:
interface Vlan11
ip address x.x.x.x
no ip redirects
shutdown
standby 71 ip x.x.x.x
standby 71 timers 5 15
standby 71 priority 250
standby 71 preempt
I also have this vlan on the fwsm.  It looks to me like were creating these vlans on the switch, pushing them to the fwsm using the firewall vlan group command.  I think...
Thanks for the link!
Jon Marshall Wed, 04/21/2010 - 09:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, firstly are you running multiple contexts on your FWSM or just one ?
If just one then having multiple SVIs for vlans allocated to the FWSM is not a good idea. The fact that most of the SVIs are shutdown is a good thing although i would question why they are there in the first place.
Of the vlans allocated to the FWSM how many have SVIs that are up/up on the MSFC ?
Jon
packetzen Wed, 04/21/2010 - 10:00
verified mode on fwsm is single context
The only active vlan interface are 5 which is my uplink to the outside world but it is not in the firewall vlan group and one other vlan that is also not in the vlan firewall group.
The only active vlan interface I have that is also in the vlan firewall group is xxx and it has the outside int ip of the fwsm.  So that sounds like I am only running one svi to the fwsm.  Perhaps someone set up those vlan interfaces incorrectly and just shut them down.
If that's the case I then only create the vlan's on the fwsm.  But I have to add the vlan id I create on the fwsm to the firewall vlan group on the switch, correct?
No wonder I was confused.
Thanks!!
Jon Marshall Wed, 04/21/2010 - 10:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sounds right then. Be aware that as far as i recall the vlan shared between the FWSM and the MSFC does not have to be allocated to the FWSM in the firewall vlan-group command. So can you just doublecheck that you actually only have one vlan with both an active SVI on the MSFC and an interface on the FWSM.
Yes, any vlans you want to add to the FWSM, other than the shared vlan mentioned above, need to be allocated to the FWSM using the firewall vlan-group command on the switch.
Jon
Related Content
