Group Listen 7911 CUCM 7.1(3)
The feature Group listen is aviable on CUCM 7.1(3) ?????
Rob Huffman
Hi Ivan,
This has been available in CCM since 4.1(3) and is
still supported on CUCM 7.x versions
Using the Group Listen Feature on the
Cisco Unified IP Phone 7906G and 7911G
You must add these Softkeys and Delete the Monitor Softkey;
GListen softkey
GLOff softkey
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7906g_7911g/4_1_3/english/group/listen/0611GL.pdf
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cuipph/7906g_7911g/7_0/english/administration/guide/11setup.html#wp1087217
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Thanks for you help
The feature is running now.
Best Regards
Hi Ivan,
Good stuff my friend, you are most welcome
Cheers!
Rob
