MSE 3350 Error: CiscoUnregisterEngine - Aeroscout Engine Is Terminated
Answered Question
Apr 21st, 2010
we have installed the MSE 3350 with the lates Context Aware Sup Service from Aeroscout
But the Service still terminated because of unexpected null node message (see below)
Thanks for any help
Best regards
Heiko
2010-04-21 17:37:20,716 ERROR CiscoUnregisterEngine - response to RegisterEngine request is invalid - unexpected null node
2010-04-21 17:37:21,718 INFO  Manager - ----- Aeroscout Engine Is Terminated -----
Product name: Cisco Mobility Service Engine
Version: 6.0.103.0
Service Name: Context Aware Service
Service Version: 6.0.101.0
Admin Status: Enabled
Operation Status: Up
Context Aware Sub Services
Sub Service Name: aeroscout
Version: 4.2.2.13
Description: AeroScout® Location Engine for RSSI and TDOA asset tracking
Active: false
Correct Answer by Lucien Avramov about 6 years 9 months ago
Ok lets try this:
1. Stop mse (well even if its actually stop, run mse stop).
2. mv /opt/mse/db/linux/server-eng.db /opt/mse/db/linux/server-eng.db.old
3. start mse
Overall Rating: 5 (5 ratings)
heiko.bachofner Wed, 04/21/2010 - 11:11
Hello Lucien
The Context Aware Sub Service from Aeroscout tries to start the service again and again.
For a few time the Registered-Field changed to "true" and then back to "false"
I just stoped the mse and start it again
/etc/init.d/msed stop
/etc/init.d/msed start
/etc/init.d/msed status
Version: 3.2.1 - 04.00.15.12
Active: false
Active: false
Correct Answer
Lucien Avramov Wed, 04/21/2010 - 11:17
Ok lets try this:
3. start mse
heiko.bachofner Wed, 04/21/2010 - 11:59
Hi Lucien
THANKS !!!!   :-)
Active: true
Watchdog Process ID: 3830
Engine Process ID: 4353
Very Great !!
Thank you very much
Best regards
Heiko
Gertjan Scharloo Thu, 01/06/2011 - 13:38
I Tried :
1. ./msed stop.
:  ,mv: cannot stat `/opt/mse/db/linux/server-eng.db': No such file or directory>>> !!!
# pwd
/opt/mse
# ls -al
total 1848
drwxrwxr-x 13 root root    4096 Dec  3 18:51 .
drwxr-xr-x  4 root root    4096 Dec  3 18:45 ..
-rw-------  1 root root       0 Jan  6 21:36 0
drwxrwxr-x  2 root root    4096 Dec  3 18:45 attach
-rw-rw-r--  1 root root 1828881 Dec  3 18:48 Cisco_Mobility_Services_Engine_InstallLog.log
drwxrwxr-x  4 root root    4096 Dec  3 18:59 dataFiles
drwxrwxr-x  8 root root    4096 Dec  3 18:45 framework
drwxrwxr-x  4 root root    4096 Dec  3 18:46 hs
drwxr-xr-x  6 root root    4096 Nov 15  2006 jre
lrwxrwxrwx  1 root root      38 Dec  3 18:48 licensing -> /opt/mse/dataFiles/framework/licensing
drwxrwxr-x 13 root root    4096 Dec  3 19:00 locserver
drwxr-xr-x  7 root root    4096 Dec  3 18:45 logs
drwxrwxr-x  2 root root    4096 Dec  3 18:45 rpms
drwxrwxr-x  3 root root    4096 Dec  3 18:45 setup
drwxrwxr-x  2 root root    4096 Dec  3 18:48 uninstall
drwxrwxr-x 14 root root    4096 Dec  3 18:52 wips
There is no directory 'db' ........
3. start msd again : ./msed start
Can you help me ?>
Thanks !
edwardzeng Wed, 01/12/2011 - 18:12
After upgrade to version 7.
It should be in your MSE:
/opt/mse/locserver/db/linux/server-eng.db
Trending Topics - Security & Network
