DSCP marking on Nexus 5000
Answered Question
Apr 21st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I'm trying to convert our existing QoS template that we use on our 3750/3560 to work on our new Nexus 5000 switches.
The ACLs and class-maps are ok, but it seems I can't do a "set dscp xx" within the policy-map on the Nexus 5000, like I was able to using the 3750/3560.
This is what I normally configure on a 3560/3750 :
policy-map QosPolicy
class VoIP
  set dscp ef
exit
class CriticalApp
  set dscp af31
exit
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
class class-default
  set dscp default
exit
exit
The "set dscp xyz" command isn't available on my Nexus 5000s. I'm running NX-OS version 4.1(3)N1(1)... I'm currently unable to download version N2 from Cisco (some cryptic error about mismatched data), so I can't verify whether "set dscp" is available there in the newer version.
Have I misunderstood something about the QoS on Nexus 5000s ?
Please advise,
Alex.
Correct Answer by Jon Marshall about 6 years 11 months ago
Alex
I don't know about v4.2 but as far as i know for the Nexus 5000 switches you only have the option to set CoS values. Only the L3 capable Nexus 7000 has the capability of setting DSCP values.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 04/21/2010 - 11:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Alex
Jon
