Is sleep mode available for 7911/42/62 IP Phones?
Apr 21st, 2010
Hello everyone,
I was wondering if it is possible to have 7911/42/62 phones go into sleep mode.  I don't see any timer settings at the device level as with the 7945/65 phones which allow them to go to sleep.  A client started a green initiative with the majority of phones being 79X2 integrated with CUCM 6.1.3-1000.16.
Does anyone know if there is some process to put the older model phones to sleep or is it not supported.  I've been given conflicting answers but no specific details.
Thank you for the help.
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 04/21/2010 - 13:22
Hi there,
Like Michael nicely noted (+5 "M" as always )
None of these models, 7911,7942 or 7962 support Sleep/Deep Sleep
or Power Save config's inherently. So you'll have to look at plan "B"
which comes at this question from a Switch/Switchport angle.
Enabling Green Practices
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/presentation_C97-466550.pdf
Power Management: Embedded Event Manager (EEM)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10195/white_paper_c11-514642.pdf
Turn off IP Phones Remotely
From Jimmy Ray & the awesome "Switchin Kitchen"
http://www.cisco.com/en/US/prod/switches/SK_E03.html
Cheers!
Huff
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
