Unity Connection Reporting
Answered Question
Apr 21st, 2010
I am not sure if I can get reporting out of Unity Conn or not. I want to be able to see
Auto Attendants which numbers are selected. Of Course if possible by day or week, or month.
Thank you!
Correct Answer by David Hailey about 7 years 1 week ago
Log into https:///cuservice and Select "Tools" then "Reports".  There is a pre-canned Call Handler Traffic Report.  It will give you the following:
  • Total number of calls.
  • Number of times  each key on the phone keypad was pressed.
  • Extension.
  • Invalid extension.
  • Number of times  the after greeting action occurred.
  • Number of times  the caller hung up.
  • Hailey
  • Please rate helpful posts!
    Overall Rating: 5 (1 ratings)
    Correct Answer
    David Hailey Wed, 04/21/2010 - 13:35
    • Purple, 4500 points or more
  • Extension.
  • Hailey
