Weird 2503 TFTP Upgrade Fails from Boot Prompt (boot)
I have 7 or so routers (five 2501/five 2503) that are in boot mode ie. R1(boot)#
The error is associated to not having an IOS in Flash or IOS wrong version in Flash?
My goal is to upgrade (install) a working 2501 ISO to all of them via TFTP to Ethernet Port which I have managed to do successfully except for the (2) 2503s by configuring E0 with IP and issuing copy tftp flash command.
The problem with the 2503s is that although I can configure e0 with an ip, there is no copy flash command!!! (copy ? produces copy flh.log)
Since the upgrade works with the 2501 bootstrap image that loads successfully prior to IOS I assume this to be the difference between the 2501 and 2503 copy commands???
Any help plz
Also Can I use an image from a working 2501 router (c2500-c-l.120-4.bin) onto a 2503?
Some Output: SHow Version
Router(boot)>sh version
IOS (tm) 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB2, PLATFORM SP
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Mon 05-Oct-98 10:52 by jaturner
Image text-base: 0x01010000, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB2, PLATFORM SPECIFIC RELEASE SOFTWARE
Router uptime is 2 minutes
System restarted by power-on
Running default software
cisco 2500 (68030) processor (revision D) with 1024K/1024K bytes of memory.
Processor board ID 02084910, with hardware revision 00000000
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
1 ISDN Basic Rate interface.
32K bytes of non-volatile configuration memory.
Output: Sh int e0 (E0 to TFP properly configured and working)
%SYS-5-CONFIG_I: Configured from console by consolesh int e0
Ethernet0 is up, line protocol is up
  Hardware is Lance, address is 0000.0c3e.7885 (bia 0000.0c3e.7885)
  Internet address is
Some Output: Copy command (no copy tftp option!)
Router(boot)#copy ?
Reza Sharifi Wed, 04/21/2010 - 14:42
I have to warn you that the 2500 series are very very slow.  If you are using them for lab 2600 are pretty cheap on Ebay.
Thanks for the tip, I am trying to fix a bunch and then upgrade at later date  - just working (or not) with what I got
Reza, please verify / help if you can then I give up ( i spent few hours now with no luck) but much abliged
If this is my output:
r1(boot)#sh version
and I am in (boot)# prompt
but cant copy/verify/sh flash (IOS) or ROM (Bootstrap)
Wtf do I do but most importantly How? - I tried everything so far
Reza Sharifi Wed, 04/21/2010 - 14:37
Hi John,
The image is the same for all 2500 series, so once you upgrade your bootstrap image to eable the copy command, you should be able to copy an image from a 2501 to 2503.
