VPN Client feature configuration for Cisco IP Phone 7945G, 7965G, and 7975G.
Answered Question
Apr 21st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I just read in “Configuring Settings on the Cisco Unified IP Phone” and found out that The VPN Client feature is supported only for the Cisco Unified IP Phone 7942G, 7945G, 7962G, 7965G, and 7975G.
We are currently using UCM 6.1 with Cisco Unified IP Phone 7945G and 7965G.
I cannot find the VPN client option on my phone.  I have upgraded the firmware to SCCP45.8-5-4S.
I check it at “You can access the VPN Configuration settings by pressing the Settings button and choosing Security Configuration > VPN Configuration” and there is no VPN Configuration option.
In the Security Configuration > after “802.1X Authentication Status” option, it is IPv6 CAPF Server.
Is there anything that I have to do in UCM or the phone so the VPN Configuration will show up and I can configure it?
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_0/english/administration/guide/7970set.html#wp1185817
sienz
Correct Answer by htluo about 6 years 11 months ago
If you notice the title of the document -
Cisco Unified IP Phone 7975G, 7971G-GE, 7970G, 7965G, and 7945G
Administration Guide for Cisco Unified CM 8.0
Michael
http://htluo.blogspot.com
Correct Answer by James Hawkins about 6 years 11 months ago
VPN client is a very new feature that is only supported in CUCM 8.0 and I am not even certain that it is fully released yet.
For UCM 6.1 an alternative would be the ASA Phone Proxy but this has some limitations.
Overall Rating: 4.8 (3 ratings)
Correct Answer
James Hawkins Wed, 04/21/2010 - 16:36
  • Gold, 750 points or more
Correct Answer
htluo Wed, 04/21/2010 - 18:38
  • Red, 2250 points or more
Michael
sienz.sienz Thu, 04/22/2010 - 08:55
Thank you all,
I just get so excited about this feature.  I guess I need to start upgrading our UCM.
Fyi,  I upgraded my firmware to SCCP45.9-0-2SR1S from SCCP45.8-5-4S and the VPN Configuration shows up under the Security Configuration.
But the soft key to enable is grey out.  So probably it will need UCM 8.0 to activate the VPN enable soft key
derveniss Mon, 04/11/2011 - 03:58
"But the soft key to enable is grey out.  So probably it will need UCM 8.0 to activate the VPN enable soft key"
The same here... How I will activate the "enable" softkey?
Thanks!!
