ASA 5510 Session Limit of 2 Error Message
Answered Question
Apr 21st, 2010
In ASDM I am try to set Maximum Number of SSL Sessions.  According to Cisco documentation my Cisco ASA 5510 should be able to support 250 simultaneous SSL VPN sessions.  But if you check my screen shot you will see that my ASA will not permit more than 1 or 2!  What is up with that??
http://www-search.cisco.com/en/US/docs/security/asdm/6_1/user/guide/vpn_web.pdf
What am I missing?  I am running ADSM 6.2 and the image is 8.21.
Correct Answer by johnd2310 about 7 years 1 month ago
ASA  comes with 2 free licences. To use more that 2 you will need to buy licences. The 250 is the maximum number the box will support.
John
Correct Answer by Federico Coto F... about 7 years 1 month ago
All ASA models (including the 5510), comes from factory supporting only 2 SSL VPN connections.
Indeed, the ASA can support up to 250 SSL VPN connections, but for that, you must purchase an additional license.
Check more information on the data sheet:
www.cisco.com/go/asa
Federico.
Overall Rating: 5 (3 ratings)
Correct Answer
Federico Coto F... Wed, 04/21/2010 - 15:36
  • Green, 3000 points or more
Federico.
Correct Answer
johnd2310 Wed, 04/21/2010 - 15:38
  • Silver, 250 points or more
John
joerggrau Tue, 05/18/2010 - 12:52
I am running into the same problem.  Does anybody know the item number for the different levels of
simultaneous connection licenses?
I need to get a PO cut and need to know the item number and price.
Joerg
Federico Coto F... Tue, 05/18/2010 - 12:57
Depending on the model of the ASA that you have you can go up to 250, 750, 5000, 10000 SSL VPN connections....
The part number will be available on the ordering guide.
Federico.
joerggrau Tue, 05/18/2010 - 13:33
Does this license file just apply to clientless WebVPN users?  Or does it
also apply to Anyconnect users?
thanks
Joerg
Federico Coto F... Tue, 05/18/2010 - 13:38
It applies to SSL connections to the ASA either client-based (anyconnect) or clientless (browser)
There are additional licenses for specific functionalities, for example to provide only the anyconnect functionality or to provide also clientless, secure desktop and anyconnect capabilities.
Federico.
joerggrau Wed, 05/19/2010 - 07:14
On a different ASA5510 I have a Security Plus license showing the following:
VPN Peers: 250
SSL VPN Peers: 2
Does this mean I can only have 2 clientless WebVPN users connected at the same time?
Joerg
David Niemann Wed, 05/19/2010 - 09:24
Anyone correct me if I'm wrong, but I believe that indicates you can have up to 250 IPSec based peers (client or L2L) and up to 2
SSL based peers (either clientless or AnyConnect).  If you want to run the AnyConnect clients for SSL VPN support
above the 2 test sessions I believe you must purchase the AnyConnect Essentials license upgrade which will increase
the SSL VPN sessions to 250 but be limited to AnyConnect clients only.  If you want AnyConnect and Clientless SSL VPN you must purchase the SSL VPN licenses or AnyConnect premium I think which is considerable $.
Jennifer Halim Wed, 05/19/2010 - 14:33
  • Cisco Employee,
David you are absolutely right.
There are 2 types of SSL license that can be purchased:
1) AnyConnect Essential license - only supports AnyConnect client, and it can support up to the maximum number of SSL connections the box supports. However, once AnyConnect Essential license is installed, the default/free 2 SSL Premium license is no longer available.
2) SSL/AnyConnect Premium license - supports all types of SSL VPN connections, ie: Clientless (WebVPN) SSL, AnyConnect VPN, and all the advance feature of SSL, ie: CSD, Hostscan, etc. This is a user base license.
Hope that helps.
