Dynamic VLAN
Apr 21st, 2010
Hi Guys,
I am trying to understand Dynamic VLAN assignment using VMPS. The VMPS Client switch is a 2924XL with proper IOS. It is configured for VMPS as follows-
vmps server     ! Location of VMPS Server...confirmed reachability from Switch to the Server
vmps reconfirm 90
vmps retry 4
The VMPS Server is ready to accept the request.
The issue is as soon as I configure the switchport, the Switch puts all the switchports in Blocking state except the Trunk port. The Switch does not recognise the Host connected on the port when configured for Dyanmic VLAN assignment. If I configure the switch for static VLAN assignment, it works as desired. The topology is very simple and is attached here.
Can you shed some light on this?
Thiyagu VG Thu, 04/22/2010 - 00:56
Hi Amit,
Can you please give us the output of "#sh spanning-tree vlan *** int ***(end station) portfast".
As you know already, the output should show us "VLAN***        enabled".
because spanning-tree PortFast mode is enabled by  default on dynamic ports.
ycae Thu, 04/22/2010 - 03:59
Once you have configured your ports as dynamic you have to disconnect the devices from the switch and connect them back. we were facing this problem too. The other option is that you execute a shutdown on all your access ports and then switch them back on (no shut) and then it should work.
I hope I could help.
