ACE configuration check-up!
Apr 22nd, 2010
Hi everyone.
I would like to check the following ace configuration,
My main question is that the ace config like below is same function?
case.1
serverfarm host NAME_of_SERVERFARM
  rserver REAL01
    probe TCP50000
    inservice
  rserver REAL02
    probe TCP50000
    inservice
case.2
  probe TCP50000
  rserver REAL01
    inservice
  rserver REAL02
    inservice
we forcus on probe,
in case,1 the probe is assigned on each real server, but in case2, the probe is only server farm, not on each rserver.
in this case. case1, case2 is same function? or not. Is there something special in two case?
finally!
in case.3
  probe icmp
  rserver REAL01
  probe TCP50000
    inservice
  rserver REAL02
  probe TCP50000
    inservice
this case is in probe, on each rserver and server farm, on server farm check on icmp and rserver check the service port.
in that case, if just one probe is dead, the server farm declare the rserver is dead ,regardless of tcp is up.
Thank you.
Overall Rating: 5 (1 ratings)
ciscocsoc Thu, 04/22/2010 - 06:56
  • Silver, 250 points or more
Case 1 and Case 2 are equivalent. A probe applied to a serverfarm is applied to all rservers within it.
Logically
  probe icmp
  rserver REAL01
   probe TCP50000
    inservice
  rserver REAL02
is equivalent to:
  probe icmp
  rserver REAL01
   probe TCP50000
  probe icmp
    inservice
  rserver REAL02
   probe TCP50000
  probe icmp
    inservice
so if either probe on an rserver fails it will make that rserver out of rotation.
This could be written as
  probe icmp
    probe TCP50000
  rserver REAL01
    inservice
  rserver REAL02
    inservice
If you want to have an rserver taken out of rotation only if all the probes on it fail then you need to add the "fail-on-all" command.
Cathy
