os patches and hot fixes for CUCM
Apr 22nd, 2010
Following are the details of the call manager. I want to know the best practice for installing os patches and hotfixes. Also if somone can tell me what upgardes should be applied to below mentioned  ver of call manager.
CUCM system ver 4.2(3)
CUCM administration ver 4.2(2)
CUCM installation id CCM4.2(3)
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 04/22/2010 - 06:14
  • Cisco Employee,
  • Hall of Fame,
    2011
The recommendation is to always run the latest patches available.
Usually you start upgrading the OS to the latest level and the start patching CUCM
The latest patch you can apply is 4.2(3)SR4b
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
