Timer Ready Not ready
j.huizinga
Level 6
Level 6
Customer has IPCC Express Premium 4.5.2
Through the "System Parameters Configuration" you can change the "Agent State after Ring No Answer"
Is there a way to increase the timer?
I mean the agent phone rings, but instead of after three rings the agent becomes not ready after six rings.
Jan
Aaron Harrison
It's the 'Timeout' setting on the 'Select Resource' step within the script.
Default is 10 seconds. .. double it to 20.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Ough, I knew that a long time ago, I forgot completely.
Thank you for the quick response,
Jan
