MPLS campus LAN virtualization and VSS
Apr 22nd, 2010
Hello
I'm going to start the evaluation of implementing the virtualization of our campus LAN using MPLS.
We'll get many inter-VLAN routing domains per VRF on the same LAN infrastructure.
The LAN infrastructure is based on C6500 implementing VSS.
Do you have experience with this kind of setup?
Any known/faced issue that might prevent the setup of MPLS on VSS enabled C6500?
Thank you
Best regards,
Andrea
Giuseppe Larosa Thu, 04/22/2010 - 02:50
  • Hall of Fame,
    Founding Member
Hello Andrea,
you will need 12.2(33)SXI2 or later  to have MPLS support
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1054826
VSS best practices
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
Hope to help
Giuseppe
ar Sat, 11/12/2011 - 20:22
I am planning to run VSS on a dual PE as well.
I cant find any related configuration docs for this.
any idea?
