IP IVR 7.0(1)SR05_Build504
Apr 22nd, 2010
Are the Expanded Call Variables suppose to disapper everytime you apply a patch to IP IVR?  I applied SR3 then I rdp to my 2 servers and open the editor.  I login to the editor and click "Settings" then "Expanded Call Variables", and nothing is there.
I manually typed them all back in.
That was a couple months ago.
I just applied SR5 and the same thing happend again.  What the !@#$%^
So do the variables get wiped out by applying the SR's? Is this suppose to happen?
Del H Thu, 04/22/2010 - 05:37
Ok, this is weird.
When I logged in to the editor using my login I did not see them
When I logged in to the editor using ipccadmin which does not have have permission so I get logged in anonymously I can see them
Related Content
