WFM install - need for sysadmin rights
Apr 22nd, 2010
Hi All,
The WFM 8.3.3 install guide states that the sql login required needs dbcreator and sysadmin privileges.
We are about to deploy WFM for a customer where the WFM database will reside in an SQL cluster, therefore they do not want to give this user sysadmin privileges.
Does it really need the sysadmin role as I would have thought if it has the dbcreator role at a system level and then the appropriate rights for the database itself it should be OK?
Aaron Harrison Thu, 04/22/2010 - 05:48
It sounds feasible to me - the other option would be for them to grant rights temporarily and babysit while you run the setup, then revoke the extra rights.
lroberson Fri, 04/23/2010 - 12:09
I have WFO both AQM and WFM.  For the SQL user, have you DBA create a separate SQL Logon in Security section. Have then Grant ADMIN rights to that User account. Yes.. it give you equal rights,but it can be restricted to the WFM_DB instance.
