Port channel in cisco WS-C6509
u346874_2
I am planning to do ethernet portchannel with two Gi ethernet ports. Any experience how L3 port channel works. If i put a ip address under e.g interface Port-channel1 config does it inherit/copy to interface GigabitEthernet 1/1 and 1/2 config.
shutdown
des PortCh
no switchport
ip address 10.1.1.1 255.255.255.0
shutdown
does ip address copy here
no switchport
channel-group 1 mode on
interface GigabitEthernet 1/2
shutdown
no switchport
u346874 wrote:
OK. thanks. So ip adress does not appear under those two Gi ethernet port config at all. It stays only under that portchannel config.
Correct, the IP address will only show up under the port-channel interface.
Jon
Reza Sharifi
The IP address is assigned under the Etherchannel interface not the physical interfaces.
Have a look at this document on how to configure it:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/channel.html
Reza
Jon
