Multiple Cisco NAC Clients
Apr 22nd, 2010
A question was posed by a client regarding the Cisco NAC solution. Is it possible for the cisco NAC client to co-exist with another cisco NAC client? Can you have two different versions installed on the same system?
My client will be dealing with plenty of 3rd parties so there is a chance the party may already be utilizing the nac client for another enterprise. Any insight would be appreciated.
jan.nielsen Thu, 04/22/2010 - 12:09
Not likely, i would say use the web agent if you are going to be supporting multiple customer installations with different versions.
Faisal Sehbai Thu, 04/22/2010 - 15:08
Two different versions? No
Two different installations? Depends. Some agent versions work with older CAM/CAS versions. Old Agent versions might work with new CAM/CAS, but that's untested and unsupported. You also will have to tweak your Discovery Host settings in the agent to the right IP/Host name for whichever network your client connects to.
