OOB Error - WLC OOB VG
Answered Question
Apr 22nd, 2010
I have configured OOB 4.5.1 VG with WLC 2100.
NAC:
CAS is located on VLAN 40 with 192.168.123.2/24
CAM is located on VLAN 60 with 192.168.199.2/24
SNMP Receiver -- community: cam_v2
WLC profile: -- V2C Read: cam_v2,
                      V2C Read/Write: cam_v2
Successful added 192.168.123.3 with WLC Profile
NAC Server is connected to Gi2/0/2 and Gi2/0/3
NAC Manager is connected to Gi2/0/1
Switch:
3750 is the core switch like follow:
interface GigabitEthernet1/0/6
description connect to WLC Port 1
switchport mode trunk
interface GigabitEthernet1/0/7
description connect to WLC Port 2
switchport trunk native vlan 40
switchport trunk allowed vlan 40,70,170
interface GigabitEthernet2/0/1
description CAM
switchport access vlan 60
interface GigabitEthernet2/0/2
description trsut_VLAN
switchport trunk native vlan 999
switchport trunk allowed vlan 3-10,40,60,70
interface GigabitEthernet2/0/3
description untrust_VLAN
switchport trunk native vlan 998
switchport trunk allowed vlan 13-20,170
Switch 3750 is the core switch.
We set Gi1/0/6 as trunk interface to WLC Port 1, Gi1/0/7 as trunk but only 40,70 and 170 with native 40 connected to WLC Port 2.
Wireless:
WLC Mgr interface is VLAN40 with 192.168.123.3/24
AP interface is VLAN7 with 192.168.120.2/24
SNMP General - cam_v2
Trap read/write: cam_v2
SSID with vlan_nac interface with Quarantee VLAN 170, and Interface VLAN 70
i did 2 tests :
  1. associated with WLC "PORT 1" <---Result : Can get the login page but fail to login (OOB Error: OOB Client <MAC></IP> is not found.
  2. associated with WLC "PORT 2" <-- Result:  Can't get the login page
WLAN set the vlan_nac interface and check the  "NAC" enabled option.
How to succes configured WLC with NAC???? Any Suggestion? or any successful case could be shared? Many Many Thanks
I attached result for reference.
Correct Answer by Faisal Sehbai about 6 years 11 months ago
I can guarantee you it's a SNMP issue or the trap traffic isn't reaching the CAM. Please post your SNMP config screenshots from your CAM and WLC.
Faisal
Overall Rating: 5 (1 ratings)
Faisal Sehbai Thu, 04/22/2010 - 15:13
  • Gold, 750 points or more
These errors point to SNMP problems. The CAM never received the trap for that particular client. Troubleshoot to see why that didn't happen and you'll find the problem.
HTH,
Faisal
szekahungdanny Mon, 04/26/2010 - 04:53
Could give more information? i double check all snmp setting on WLC and NAC is correct and successfully add WLC device into NAC.
However, i wanna to ask L2 adjacent between WLC and NAC Server..
what it mean ??
description trust_VLAN
Should i add any native vlan 998 or 999 into Gi1/0/6? in order to snmp trap successfully deliver to CAM?
How can I check SNMP trap fail to send to CAM? .... i have 2 clients ..both have same issues.. !!!
Correct Answer
Faisal Sehbai Mon, 04/26/2010 - 18:49
Faisal
szekahungdanny Tue, 04/27/2010 - 09:27
Yes. I believe you are correct..
I find SNMP community name could not use somethings like "Public" and "Private" and also
Read Only and Write should be different name.
Once I configure cam_v2 as Read Only and cam_v2_1 as Write community. Finally, It is success ...
Although i still double how come i can't use public or privarte .. or could or could not use same name, follow these rule seems success always.
Thanks very much.
