OSPF Point-to-Point Question
Answered Question
Apr 22nd, 2010
I am trying to understand the following configuration, any help would be highly appreciated.
From the destribution block we have uplinks to core , where we used point-to-point ( not sure why ) also priority and cost was configured ....will it work ?
DIST1A#sh run int t5/5
Building configuration...
Current configuration : 194 bytes
interface TenGigabitEthernet5/5
description Connection to CORE1B T1/5
ip address 10.8.8.61 255.255.255.252
ip ospf network point-to-point
ip ospf priority 255
arp timeout 1200
end
DIST1A#sh run int t5/4
interface TenGigabitEthernet5/4
description Connection to CORE1A T1/5
ip address 10.8.8.57 255.255.255.252
arp timeout 1200
end
DIST1B#sh run int t5/5
Current configuration : 190 bytes
description Connection to CORE1B T2/5
ip address 10.8.8.69 255.255.255.252
ip ospf cost 255
arp timeout 1200
end
DIST1B#sh run int t5/4
description Connection to CORE1A T2/5
ip address 10.8.8.65 255.255.255.252
ip ospf cost 255
arp timeout 1200
end
josh
Correct Answer by Giuseppe Larosa about 7 years 1 month ago
Hello Josh,
having set the OSPF network type to point-to-point no OSPF DR election occurs on segment and so the ospf priority  is not effective on this link.
the use of OSPF  network point-to-point on LAN interfaces is used for fiber based point-to-point links where you know that there are only two devices and you want to save some resources by avoiding to elect one router OSPF DR and one OSPF BDR.
I think that the OSPF priority has been set as a safety measure should someone remove on both sides the ip ospf network point-to-point command it would be clear who would be elected OSPF DR on segment.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 04/22/2010 - 10:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Josh
Not sure exactly what you query is. Basically from each distribution switch you have 2 L3 P2P uplinks to the core switches. So yoy have a routed L3 distro/core setup which is quite common. Each distro switch will see 2 equal cost paths to destinations reached via the core.
Is there something specific in the config you think might not work ?
Jon
josh94950 Thu, 04/22/2010 - 11:47
Jon,
Thanks and you are right on distribution blocks to core, however I am confusing with the priority and cost on point-to-point interface  .... is that a reason to configure in this way or ..
from Dist 1A   ------------------>    Core 1A            Priority is setup to 255  , default cost
       Dist 1A   ------------------->   Core 1B            Priority is setup to 255 ,  dafault cost
From Dist B -------------------->   Core 1A             Cost is 255 , default  priority
         Dist B -------------------->   Core 1B            Cost is 255 , default priority
Correct Answer
Giuseppe Larosa Thu, 04/22/2010 - 12:53
  • Hall of Fame,
    Founding Member
Hello Josh,
Hope to help
Giuseppe
